Ac Water Valve
bobscuda67
Michigan
Hey guys, I was at the Nats. last weekend and I noticed that the a-body cars with ac had a watervalve on them. My 67 barracuda is a factory ac car but it has no valve or holes for one. Should I be looking for one or did some cars not require them?
do you mean a valve on one of the heater hoses??
Wasnt necesarily required as the heat can be controlled by either a valve (allows coolant to flow thorugh the heater core when heat is selected) or by a flapper in the heater box (directs the heat where you want it)...
