Actual Long Tube Header Instructions 1967-74 All B & E (A & F Bodies) 273-360
ddart cart
NJ
This applies to any cheaper non TTI or Dougs long tubes:
5901HKR (black painted), 5901-1HKR (silver ceramic),
5901-3HKR (Darkside black ceramic), & 5901-4HKR (Titanium)
COMPETITION DODGE/PLYMOUTH HEADERS
NOTE: WILL NOT FIT MOTORS EQUIPPED WITH AIR INJECTION PUMP WITHOUT MODIFICATION.
NOTE: Hooker headers for MOPAR 318-360 engines will bolt on the popular aftermarket B-A heads. However, because the exhaust port centerline on these heads is 5/8” higher and 3/8” out from the engine centerline compared to stock heads, some header modifications will be required for installation. Spark plug locations require cutting the header flanges for clearance.
Thank you for making HOOKER HEADERS your choice in a high-performance exhaust system. Extensive dyno/track testing has
enabled HOOKER to offer the most advanced design in exhaust systems. The installation, while not complex, will take a certain amount of time. However, the additional horsepower and improved performance will more than justify your efforts. Proper installation and maintenance will ensure long life and maximum performance from your hooker exhaust system.
WARNING! Breaking in an engine with ceramic-coated headers WILL result in damage to the coating and will VOID all warranties. Ceramic-coated headers require several heat cycles to fully cure before they will withstand extreme heat.
HOOKER recommends using a cast-iron exhaust manifold or an old header to break in new engines to avoid coating damage.
BEFORE STARTING
Your vehicle must be raised a minimum of 36 inches. A floor hoist is ideal. If no hoist is available, we strongly urge the use of axlestands as a safety measure.
CAUTION! YOUR CAR SHOULD NOT BE SUPPORTED ON A BUMPER JACK.
INSTALLATION PROCEDURE – PLEASE READ CAREFULLY
LEFT SIDE:
1. 2. 3. NOTE: Disconnect the battery cable to prevent damage to the electrical systems.
Remove the stock headpipe and exhaust manifold. Remove the spark plugs and (if stick) clutch linkage.
Drain the radiator (coolant may be reused, if drained into a clean container). Remove the front and rear studs from the head.
Engines with smog heads (but without smog pump) must have the smog air holes plugged. Purchase (8) 1/4”-20 x 1/4” long
Allen head set screws. Thread the holes with a 1/4”-20 tap (use a small wrench to turn the tap). Make sure the screw heads are flush with or below the exhaust port service. See Figure A.
4. Remove the left side tie rod from the drag link. Remove the drag link from the Pittman arm. Disconnect and remove the starter.
Remove the shift linkage and kickdown linkage.
5. Starting from below, work the header up into position. Hang the header on the front stud.
NOTE: Some vehicles will require raising the engine approximately 3” to install the headers. Remove the center bolt from the motor mount. Also, on some models, it may be necessary to remove the bolts holding the steering box so that it may be moved aside. Use a board between the oil pan and jack. Work the header into position, lower the motor, and replace the motor mount bolts. Replace the bolts for the steering box and tighten.
6. With the header loose, replace the starter. Reconnect the drag link to the Pittman arm and the tie rod to the drag link.
7. Remove the header from the front stud, positioning the flange gasket. Start all header bolts (most restricted first).
NOTE: We recommend using a sealant on the threads of the bolt used to replace the rear stud (to prevent leakage of coolant).
8. Tighten all header bolts evenly. Replace spark plugs.
9. If stick, replace the clutch linkage. If automatic (with shift column). Modify linkage according to Figures B & C and reinstall.
Replace the kickdown linkage.
10. Check the power steering hoses and (if equipped) automatic transmission cooler lines for adequate header clearance. Reroute, as necessary.
RIGHT SIDE:
1. 2. NOTE: Remove the stock exhaust manifold, spark plugs, and oil filter.
Remove the studs from the head and brace from the engine to the bellhousing (if so equipped).
Engines with smog heads (but without smog pump) must have the smog air holes plugged. Purchase (8) 1/4”-20 x 1/4” long Allen head set screws. Thread the holes with a 1/4”-20 tap (use a small wrench to turn the tap). Make sure the screw heads are flush with or below the exhaust port service. See Figure A.
3. Remove the center bolt from the motor mount.
4. Raise the engine several inches (using a flat board between the oil pan and the jack).
5. Starting from below, work the header up through the chassis into position.
6. Position the gasket and start all bolts.
7. Lower the engine and replace the center bolt in the motor mount.
8. Tighten all bolts evenly.
9. Replace the oil filter. Reinstall all the steering linkage removed (double check it).
10. Check the clearance between pipe (R-2) and the idler arm. It must be 1/4” or more. If not, replace the motor mounts.
11. Check that all gas lines, brake lines, and electrical wires have sufficient clearance. Reroute, as necessary.12. NOTE: Purchase Hooker Reducer Kit, P/N 11030HKR, to connect the headers to your stock exhaust .
13. 15. Refill the radiator and connect the battery. Replace the spark plugs.
14. Start the engine and check for leaks. When finished, give your vehicle a test drive, checking carefully for any new noises. After several days of driving, retighten all bolts.
Any questions? Please contact Technical Service: 1-866-464-6553 or 270-781-9741. For online help, please refer to the website:
www.holley.com.
5901HKR
Revision Date: 5-10-19
1974 Dart Custom. Cliff notes from my install experience:
Safety first! Jack stands are typically 15”-16” and even if you find some that meet the 36” requirement, I would strongly advise not doing it this way. This is not a gentle process and your life depends on how the car is supported! At 36” this job would be an absolute nightmare, which it already is. Fortunately someone local rented me their 4 post lift, for $100.
The install took 10 hours not 4. I wasn’t confused, incompetent, or held up by any particular part. The job is just a bear. I sensed this way back, and tried to avoid the headache by using tight tube shorties. Denied! One shop said connecting the exhaust wasn’t possible, another said it would take all day $$$ and choke the exhaust around the starter/steering.
The install is all about the driver side. You must remove all shift and kick down linkage, I tried not to, but no go. You also have to unbolt the shroud, and remove the distributer cap, they will stop you from jacking the engine up enough to clear the header. I had to notch the k frame a little, and use a large pry bar to get the driver side header past the fire wall and power steering. I did not have to dent the headers anywhere for clearance.
The juice was worth the squeeze. The car sounds way deeper with open long tubes versus short tubes. More low end hp is noticeable.
A newer, tinted out hemi charger rolled up along side me on the way home from installing so I gave her a little throttle pop, no speeding. The charger immediately got behind me and rode my *** for 10 minutes which was annoying. Probably was one of our public servants in an unmarked public service vehicle lol.
Hopefully this helps someone approaching this process. Good luck and be safe!
