famous bob
mopar misfit
I believe your theory is correct. I’m running a 190 degree stat. I drilled a 3/16” bleed hole in it. My car runs at 185-195 at cruise and 190-200 in town in 85/90 degree summer weather. Parked and off it climbs to 210 and as soon as it starts drops to 190. I also use a 7# cap and an overflow capture/reuse tank.
Think about which side or top/bottom ur fan would stick out of the shroud if u went to a bigger fan. A 17' fan would cool way better than a 15' . I cut the top out of my shround and built a round /raised top and had it heli arced in , the pass. side is almost to the edge of the shroud .
Did u cut the original mounting flanges off , and put new ones on it ? Mine were sticking out about 9/16" in front of the rad/ before I cut them off. The had four , 1 1/4' alum. angled brackets heli arced on , making the rad. sit flush w/ the cradle . I didn`t even trim the cradle out to expose the tanks on my crossflow , and just lined the 22" wide core up w/ the cradle opening. I could have raised the rad. up a little higher in foresight , and may not have needed the raised fan hump , but --------
-pic before shroud
