Taconite
Active Member
I have a 69 Cuda that is a column shifter.. It was a 904 and now it has a 727 reverse shifting pattern. The shifting linkage for the Column to the transmission is incomplete and does not function properly. So, I am thinking of adding a floor shifter. I like the Lokar linkage shifter it seems more direct to the transmission as opposed to a cable shifter. Thoughts?
