Adhesive question
scrowe
Wilmington, Ohio
Looking for the adhesive that is under hood between sheet metal and brace/frame of hood. It appears to have been caulked in. Thanks in advance.
You might go by an automotive paint supplier and talk to them about panel adhesives. They're two-part (like epoxy) and designed for bonding. I wouldn't necessarily try to remove the old stuff - just squirt some between where it has separated.
i use SEM adhesives. but they all seem to work fine. like was mentioned above, i wouldnt try to remove the old. i'd just add to it.
