I'd use a polyurethane glue/caulk. Varies from spongy Dow foam to thicker PL1 construction adhesive. Gorilla Glue is in-between, foaming somewhat. All foam a bit and stay flexible. With no bubbles, it is polyurethane varnish, but that is too stiff. Cheaper in the large caulk tubes. One difficulty is that once you start the PL1 caulk, it keeps coming out for a time after you release the plunger. Not a problem if doing a large area, and less as the caulk tube gets used up. As tenacious as the mastic tape used to seal roofs and ducting.
