anyone ever heard of or used this before?
http://www.speedtweekerz.com/index....facturer_id=0&option=com_virtuemart&Itemid=26
I had one - it was nice to be able to change the jetting with a screwdriver, but my carb had so many issues it needed a lot more than a jet change to save it. I ended up ditching the carb altogether and went EFI.
Where Can I Buy A Set Of The Hollley Float Bowlsthat Allow Me To Change The Jets Easy And What Do They Look Like?
Billy tried them a few months ago. Without an ounce of tact, I'll say
THEY SUCK!!!
THEY ARE MADE OUT TO BE GREAT BUT THEY ARENT WORTH THE MONEY AT ALL. BUY A SET OF THE HOLLLEY FLOAT BOWLSTHAT ALLOW YOU YO CHANGE THE JETS EASY . THE COST FOR BOTH BOWLS IS LESS THAN THE COST OF 1 ADJUST A JET.
JUST MY 02 CENTS WORTH
So it worked good for you except other issues huh? That's one for and one against.
Well, it did allow adjusting the main jet. Basically, that carb had been worked over by someone who had a milling machine and very little of a clue about Holleys. It had stuff like a single pumper with mechanical secondaries, looks like he'd tried to alter the idle circuit in a way that I never could figure out but always left it pig rich at idle, and there were a lot of other things wrong with it.
