BillGrissom
All I found perusing my 1964 Plymouth Service Technical Manual was pg 9-3:
Tappets - Clearance Valve Stem and Rocker Arm Pad (Engine Hot) 0.010" Intake, 0.020" Exhaust
I couldn't find a photo or description how to measure it, nor anything about measuring with engine running. From 1976 to 1994 (stolen), I owned a 1969 Dart 225, and began doing my own repairs. I now have a 1964 Valiant 225. I recall adjusting the valves cold and later checking while still hot, and no difference.
I wonder how you adjust with engine running. I imagine you slip the feeler gap in the gap and adjust until you just stop hearing a tic the gap. If not, please explain. I saw a mechanic do it once after a head job, with engine running. It wasn't flinging oil, so perhaps he had lowered the idle. I don't recall seeing him use a feeler gage, but perhaps had earlier. Seemed he was tweaking them by the ticking sound, but didn't watch close. That was 1978, back in the day when every mechanic knew the slant.
My 1985 M-B diesel has a solid valve train (OHC with "follower" which pushes on valve stem). One doesn't adjust with engine running, per the fastidious M-B procedures. I recall best to do with engine hot, though I recall doing both "warm" and hot and no difference.
