I have crane gold rockers on my car and need a little help with the adjustment.
According to Edelbrock, I need to go to zero end play then turn the
adjuster 1/4 turn and lock them down. Ok all fine and good. These
are hydraulic lifters so I could probably get by with a half turn or so
right? Here's my problem. I adjust to between 1/4 and max of 1/2 after
I have no end play BUT after the end play of the pushrod is taken up
I can still compress the lifter plunger down say almost .100" is that
normal? I am doing this with the engine quite hot. Would the oil pressure
when it's running take out that endplay or am I having some lifter go bad?
I have some valve clatter so that is why I am adjusting them slightly more
than the 1/4 turn but thought I look for experienced advice while I have
it apart.
She clatters hard on startup but after it is warmed up it's better and if
I don't let her sit for a week without driving it's also better.
The pictures show how much I can compress the lifter plunger by hand
after the preload is set to 1/4-1/2 turn.
Thanks,
Doug
it apart.
Thanks,
Doug
