justinboor
How often should I check or adjust the rocker arms on a Magnum 360 build? I am running a Hughes Engines cam (208º intake, 214º exhaust at .050" on 114º LSA). I'm running their recommended springs, push rods, and adjustable roller rocker arms. New stock hydraulic lifters. Mostly stock rotating assembly with KB Performance pistons. Engine runs great. I just started to hear what sounds like valve train noise when the engine is warm after about 300 miles. I'm not sure if I'm looking for a bad lifter, or if new adjustable roller rockers just need adjustment after break-in. Thank you!
