I put on the my new high raise manifold so now the old kick down and throttle links sit too low to connect. I also no longer has a place to mount the coil on the manifold now. Any suggestions? Thanks
I modify the brackets and extend the kickdown via welding... You can buy kits to help but I find it's cleaner and much cheaper to re-engineer it. I also hate the look of coils on the bodywork...lol. You can modify a factory coil bracket to bolt to the intake mounting bolts too.
