[SOLD] Aeromotive billet injected regulator and pressure gauge
physixx
Edison, NJ
I have for sale an Aeromotive injected fuel pressure regulator with a liquid filled 0-100 psi gauge. This regulator is a true billet A1000 injected bypass regulator that is specifically designed for use with Aeromotive's A1000 fuel pumps.
http://www.summitracing.com/parts/aei-13101/overview/
Adjustable base pressure from 40 to 75 PSI
Gasoline and alcohol compatible
Fuel pressure rises on a 1:1 ratio with boost
O-Ring Boss-10 inlet ports and O-Ring Boss
-06 return port
1/8"" NPT gauge port
The A1000 series Injected Bypass Regulator applications are for engines up to 1000 HP, has a 30-70 PSI Adjustable Base Pressure and is designed with two -10 AN inlet ports and one –6 AN return port. I would like to get $100 for both plus the shipping.
Ken
Edison, NJ
