After four years, my underhood resto is finally complete.
cruiser
Bloomington, MN
Hello All:
First, thanks to everyone who took the time to read my 32 chapters of component restoration that I've posted since I bought my 1974 Gold Duster in April of 2019. I hope they've helped you with your own component resto. This is my final report after completing my engine compartment restoration earlier this month. My goal has always been to keep my car as stock and original as possible. It's not a rare or valuable car - I know that. But I've always been a big fan of factory stock restorations which explains why I've poured the time and care into renewing my engine. The first photo shows what I started with in 2019 - a dirty, sloppily maintained engine compartment that needed a lot of help. Step one was to evaluate what I had: A non numbers matching but correct 1974 225 inch slant six block with an incorrect 1975 "peanut" cylinder head, mated to the original numbers matching A-904 Torqueflite tranny. I immediately found and installed a correct 1974 cylinder head, so now I had the big stuff knocked out. The rest was all little detailing. The next four photos show the finished result as of yesterday. For those of you who enjoy all the little details, I'll go over what I've done item by item. Please feel free to skip over this stuff if you're not into detailing like I am.
* Hood: Non original but correct 1974 hood installed after the factory hood was damaged in October of 1975 after hitting a drunk pedestrian. Has a new repro underhood pad.
* Radiator yoke, inner fenders and firewall: All original including original paint finish that I restored.
* Radiator: Correct part number re-cored and rebuilt radiator with the 1974 model year only NOS green radiator cap.
* Engine block: A parts store replacement short block that came from another 1974 A body car, but the correct engine for my Duster, painted in the right version of Chrysler Corporate Blue. New water pump, Stant 195 degree thermostat, fuel pump, Holley 1945 date coded carb, rebuilt correct part number and date coded alternator and starter, NOS date coded ECU, voltage regulator and choke pull-off, new ballast resistor, starter relay, seat belt interlock module, and NOS cruise control vacuum servo with two factory green clamps on the vacuum supply line. Fully restored original air cleaner with NOS internal temp sensor and working heated air bypass door. New heated bypass air duct, identical to the original. Unrestored correctly dated PCV valve in its factory original Chrysler Corporate Blue engine paint finish. New brass coolant temperature sensor.
* Correct part number date coded ignition coil in its original finish, mounted to block with restored clamp.
* Used but nearly perfect replacement forward engine compartment (firewall to alternator/coil/voltage regulator) wiring harness to replace the damaged original.
* Intake manifold: Factory original with correct single vacuum tap for the power brake booster.
* Exhaust manifold: Factory original, powder coated and attached to the engine with correct brass slide washers, cone washers and triangular manifold keepers.
* Fuel line and filter: Repro with correct date coding. Fuel, vapor and coolant overflow lines installed with factory Keystone crimp clamps, not screw type hose clamps.
* Steering pump and gear: Factory original units in their original finish. New pressure and return lines.
* All belts and hoses: Replaced with the best stuff that I could find, installed with factory style spring clamps, not hose clamps.
* Wiper motor: Rebuilt and restored original motor.
* Brake booster: Rebuilt original unit, zinc plated with correct part number decal.
* Master cylinder: Incorrect replacement aluminum and plastic MC (I have the restored original in storage).
* Windshield washer motor and reservoir: Factory original.
* Battery: Reproduction 12v Group 24 absorptive glass mat (AGM) battery, resting on the original restored battery tray. Correct battery strap, j-bolt and nut set.
* Fender tag: Correctly formatted replacement for the missing original, based on the original broadcast sheet and window sticker (both of which I have). An original inspection stamp metal tape is fastened under the forward fender tag screw.
If you expand the photos you'll get a better idea of how everything looks. I do this to serve as a resource for those of you who may be restoring your engine bay and could benefit from the research that I've conducted. Feel free to access any of the aforementioned 32 chapters for more detailed info on the resto of the individual components mentioned above. And yeah, I know that its only a slant six, but I still hope that you enjoy the photos. Again, many thanks to everyone who helped me so much to get my motor compartment to this point. Be well, all!
Great job Cruiser. I enjoyed the series. The car looks awesome.
Sorry they were so hard on you about the "Bent thing". LOL :lol:
I'm sure there are those who would argue it was senseless to do that to a slant 6 car, but I like it. You've really done a great job on it.
Hello All: First, thanks to everyone who took the time to read my 32 chapters of component restoration that I've posted since I bought my 1974 Gold Duster in April of 2019. I hope they've helped you with your own component resto. This is my final report after completing my engine compartment restoration earlier this month. My goal has always been to keep my car as stock and original as possible. It's not a rare or valuable car - I know that. But I've always been a big fan of factory stock restorations which explains why I've poured the time and care into renewing my engine. The first photo shows what I started with in 2019 - a dirty, sloppily maintained engine compartment that needed a lot of help. Step one was to evaluate what I had: A non numbers matching but correct 1974 225 inch slant six block with an incorrect 1975 "peanut" cylinder head, mated to the original numbers matching A-904 Torqueflite tranny. I immediately found and installed a correct 1974 cylinder head, so now I had the big stuff knocked out. The rest was all little detailing. The next four photos show the finished result as of yesterday. For those of you who enjoy all the little details, I'll go over what I've done item by item. Please feel free to skip over this stuff if you're not into detailing like I am.
* Hood: Non original but correct 1974 hood installed after the factory hood was damaged in 1977. Incorporates a new correct style hood pad.
* Engine block: Out of a 1974 A body car but the correct motor for my Duster, painted in the right version of Chrysler Corporate Blue. New water pump, Stant 195 degree thermostat, fuel pump, Holley 1945 date coded carb, rebuilt correct part number and date coded alternator and starter, NOS date coded ECU, voltage regulator and choke pull-off, new ballast resistor, starter relay, seat belt interlock module and NOS cruise control vacuum servo. Fully restored original air cleaner with NOS internal temp sensor and working air bypass door.
*Steering pump and gear: Factory original units in their original finish.
*All belts and hoses: Replaced with the best stuff that I could find.
Proud of you.
Nice to hear of a project completed. Slant 6s have definitely earned their place in history.
I remember as a young man 16, the Green Giant Pea Combines all had slant 6s in them. They would just run and run and run. The combines would break down, but the Slant 6s just kept on rolling.
Hey @cruiser from Bloomington MN
Farmington MN here.
Have to meet up with you at the "Buck Hill" cruise in this Summer.
Once again, nice detailed job on your Slant 6 engine bay.
She was a fast machine, she kept her motor clean
She was the best damn woman that I ever seen
She had the sightless eyes, telling me no lies
Knocking me out with those American thighs
-AC/DC
Nice work, your attention to detail is impressive. Well done sir! 65'
That is one awesome job and the finished product looks great! You are an inspiration to those of us who enjoy our slant 6s and I look forward to using your detailed documentation as I work on my restoration. Thanks for sharing.
I don't know, I think you should put it all back the way it was.
:rofl:
When can you start on mine?.
Looks fantastic!
Like you just picked it up, brand new, from the dealership!
Yeah, that was what I had in mind all along. I've seen many very impressive engines at car shows over the years - all impeccably restored. But where are the impeccably restored slant six engine bays? You just don't see them because - lets face it - a slanty is no where near as sexy as a hemi engine, nor is it as valuable. So yes, I was shooting for the look that you would see on a brand new Duster on the showroom floor in late 1973 if you popped the hood. I think this is pretty close to what you would have seen back then.
Farmington MN here.
As a former Lakeville resident and ( @George Jets ) Green Giant employee, I agree about the slant 6's. Great Job on the restoration, it looks awesome!
I always get a kick out of the sound they make when they crank over.
