inkjunkie
Been on the phone with my body guy. I bought a hood from US Body Source. It is a hood that has a support structure so it can use hinges with light weight springs. It is to heavy for the light weight springs. While it lines up perfectly with the fenders/cowl when it is just layed on there whe you put the hinges on it does not. EZ started measuring everything and noticed that the structure does not have the same distance side to side. He measured it at the front hood bolt to the side and came up with a 3/8" difference.
