The rear cable exit shifters, is the shift pattern reversed on a reverse valve body 727? This is all new to me, just switched from a 4-speed to automatic Coan reverse valve body 727. I didn't ask Coan about shift cable issues when routing from the front, didn't know till I got into it. Heat from the headers (Hemi) is going to be a problem. I have DEI heat shield sleeve on the cable, but not sure if it's going to live. Looking for options if the way I have it fails.
