plyduster73
I put a small cheap tach on the duster but Im having trouble locating a good place to tie into the lighting so the gauge will be lit at night.
It is mounted hanging down from the bottom of the dash beside the hand brake handle.
This is not a permanent tach as I will eventually put a new dash in it but I want a tach will Im driving the bugs out of everything.
So, would y'all just tie into the lighting of another working gauge or try to get the wire to the light switch ( which is behind the fuse box, I already tried that for several hours).
Thoughts?
Thoughts?
