Aiming headlights
Electrical and Ignition
  1. 360Scamp
    360Scamp Mopar or No Car
    550
    43
    Nov 12, 2013
    Herrin, IL
    Local Time:
    4:49 AM
    I just upgraded my headlights for better viewing at night. My old headlights were way out of adjustment to shine on the road and what Im looking for is the way to properly adjust my headlights. I adjusted them the best I could to be focused on the road.
    What Im trying to find out is, whats the distance from the wall to the front of the car, and what should the measurement be from the ground to the headlight pattern on the wall be?
    Thanks in advance with my problem
    [​IMG]
    [​IMG]
  2. Darter6
    Darter6 Well-Known Member
    3,935
    1082
    Jan 16, 2008
    Nevada
    Local Time:
    2:49 AM
    The old school way, Level as possible,we used to use a garage door to get a horizonal line,car back about 30 feet,measure distance from ground to center of headlite,adjust both lites off to the curb side some,adjusting the driver side headlite more to the curb side as to not blind the on coming cars.Again just a old school way.
    I like the looks of the Scamp.!!
  3. memike
    memike Super Moderator Staff Member FABO Gold Member
    49,536
    10042
    Jan 8, 2006
    on the hill
    Local Time:
    4:49 AM
    on the wall/garage door 8 feet away measure the height of your lights on your car center, walk to the wall/garage door and put a piece of tape the same height as your head lights
    center high beam should hit the tape center, low beam should drop 6 inches below at 8 feet away, this was the way we did it at the dealer It works the same way even if it is jacked up or even stant's This was 12 years ago
  4. memike
    49,536
    10042
    Jan 8, 2006
    on the hill
    Local Time:
    4:49 AM
    I like this even better :glasses7:
  5. 360Scamp
    550
    43
    Nov 12, 2013
    Herrin, IL
    Local Time:
    4:49 AM
    Thanks for the info guys and thanks for the kind words on my car. Its Seymour Scamp's old car
  6. memike
    49,536
    10042
    Jan 8, 2006
    on the hill
    Local Time:
    4:49 AM
    I thought you have had that Scamp for a long time, how long have you had Semour's Scamp ? Yes a very nice Mopar :hello2:
  7. 67Dart273
    67Dart273 Well-Known Member
    40,297
    7953
    Oct 14, 2010
    Idaho
    Local Time:
    2:49 AM
  8. 4spdragtop
    4spdragtop FABO Gold Member FABO Gold Member
    27,064
    6669
    Aug 28, 2009
    Ontario
    Local Time:
    4:49 AM
    Good info, Loris Kia needed to have them adjusted. I knew there was a certain distance from a "wall" but couldnt find any specs for the life of me on the net. The dealership couldnt even tell me......
  9. Bad Sport
    Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
    36,432
    16339
    Jun 12, 2010
    The Wolverine
    Local Time:
    5:49 AM
    I usually go out in the street at night with the car level I cover the driver side headlamp and adjust the right side so it runs straight with the edge of the street/road and the concentrated beam about 60 feet out.
    Then I cover the right side headlamp and adjust it so the concentrated beam is about a two feet to the left of where the right one was, in other words angled toward the right when on low beam.
    Then check the high beam using the same method. Cover one then the other. At that point the driver side on high beam should have moved the concentrated beam out further and to the left more.
    Then I sit in the car and go from low to high and see if it's where I like them.
    May not be right, but it has worked for me for 35 years.
  10. 360Scamp
    550
    43
    Nov 12, 2013
    Herrin, IL
    Local Time:
    4:49 AM
    No, I have had it since November 2013
  11. 360Scamp
    550
    43
    Nov 12, 2013
    Herrin, IL
    Local Time:
    4:49 AM
    Cool thanks, alot of good options thanks guys
  12. kt340sport
    kt340sport Well-Known Member
    1,732
    18
    Dec 23, 2006
    Miramichi N.B Canada
    Local Time:
    4:49 AM
    Great to know , i have to do mine .Buy the way ? anybody know what chrysler used for brand name headlights back in the day 1973 , i think mine are mismatched .
  13. 72_dart
    72_dart Well-Known Member
    91
    1
    Jul 27, 2013
    Chicago burbs
    Local Time:
    4:49 AM
    What I do is simple. Level ground and a wall. Pull up close to the wall then slowly back up. While your backing up watch where your headlights are on the wall. When you back up the light shouldn't move it will get bigger but shouldn't walk away from where it was when you're up close. If when you back up and the beam climbs up you need to adjust it down. If it walks to the right , adjust it to the left. Just keep adjusting until the beams stay put.
  14. inkjunkie
    inkjunkie Well-Known Member
    16,984
    2031
    May 24, 2009
    Local Time:
    2:49 AM
