air bag to go
blasterboy
Active Member
anyone know if a air bag can be taken off a 93 lebaron steering column so as to put on a grant wheel . column is not in the lebaron, it is going into a plymouth street rod.also need wiring diagram for 93 labaron column only please
air bag should be simple to remove...the one on my neon was as simple as taking two screws from the back of the horn button out and the rest was self explanatory...it came out in a bundle
got that so did you put on after market wheel, or did they do something to the top of column to keep you from doing that.
