Take the hose off at the tank and the line at the pump coming from the tank. block one end and put hand vacuum pump with a guage on the other. if it loses vacuum you got a leak. also take off the manual pump and depress the arm while holding it depressed block off the intake port and leave off the arm, if it releases slow the pump is on its way out or has a bad check valve which is common on a cheap auto-zone pumps. If the tank is over a quarter full it should be drawing fuel only. Air getting into the system although does happen on some cars without any effects, does not mean it is operating correctly. Do these checks and i'm sure you'll find its sucking air somewhere, if there is bubbles. I find more bad fuel lines then pumps. Just a heads up.
