66340SEDAN
FABO Member #3649
I am working on a 1966 Valiant 340 4-speed. Which intake would you guys go with? I have mopar M1 single plane and a Crosswind (air-gap) dual plane intake. I have 4.10 gears, 510 lift cam, Hooker comp hedders, 2.02/1.60 valve heads, and a 650 Holley double pumper. I will be going with a mopar super stock hood scoop so clearance is not a issue. Should I run a carb spacer on either of these? Any suggestions would be great! :thumbup:
