RichardJ916
Yesterday I had a New Pitman Arm, Center Line, and Idler Arm replace due to a problem with slop in the pitman arm and center line. The place I took to have the work done was a good place for front end alignment on newer car but and I am not sure how much the tech has in doing older cars like my 1972 Plymouth Duster. Here's my question...The steering is 100% better now meaning no slop in the searing wheel but after I was reading the specs sheet on front end alignment report it seems like it is still out of spec as compared to the Mopar Specs. Could someone tell me if this is going to be ok or should I take it to another shop to have the front end looked at again. Am I going to be getting tire ware with this setting or other trouble.
I am sure in the near future other parts are going to be needing replacement but just looking for a answer to the specs from the print out machine.
Here are the specs.
Left Front Right Front
Camber .6Deg. Camber -1.2Deg.
Caster 3.1Deg. Caster 2.5Deg.
Toe .11Deg. Toe .13Deg.
Total Toe .24Deg
Steer Ahead -.01Deg.
Please let me know what it looks like to you.
Here are the specs.
Total Toe .24Deg
