goldfish65
Recently I made some changes to my '65 Barracuda. Now my car's tracking is less in control than it was before. On the highway it doesn't stay in the lane as well and the handling on twisty roads is not as accurate. The steering wheel doesn't return completely to on-center after going around a corner like it used to.
Here are the changes: 14x7 wheels and 205/70 tires to replace the original 13"ers. New rear leaf springs 1" over stock height. Four new KYB shocks. New idler arm and pitman arm. Frontend alignment done to stock spec's.
I had a reputable shop do all the work, I have used them a lot over the years. They also adjusted the tightness of the steering box which made the car very twitchy so we backed it off a little bit, and then a little more, until it had a little play. I wonder if it needs just a tad more backing off? Would a change in the alignment specs help?
Does anyone have some advice on how to improve the above handling issues? Goldie has a great new stance but the handling was better before I made the changes. I'm kinda bummed, after spending quite a bit for everything. Thanks guys...
