HemiTM
When we started the freshly rebuilt 360 the other day, it ran for 5 minutes and got up to 240 degrees. Shut it off at that point. While it was cooling down, I decided to take a look at the oil. It looked like coffee creamer. Drained the oil and removed the filter at that point. Pulled the # 8 plug and noticed I had water in the cylinder. Pulled the M1 manifold and resealed the water ports along with new intake manifold gaskets. Poured oil through the motor and drained it. Manually circulated oil through the motor and I feel we had it cleaned out the best we could. Put everything back together and let it sit about 24 hours. This morning I went out and started the motor. It ran great for about 90 seconds then started to miss. I pulled out the #8 plug and water gushed from the cylinder. So at that point I pulled all the plugs. Removed the coil wire and turned over the motor. It looked like a fire boat shooting water from all nozzles.
At this point I have removed the passenger side head and am working on the driver side. The heads are going in to be resurfaced tomorrow. Could 240 degrees blow new head gaskets? Did I miss something in the assembly? I am stumped. Hoping to find the problem and fix it so I can make it to MATS. :banghead:
