MOPAROFFICIAL
If it has tits, it's a liabilititty.
Which is better in your opinion, the full knock down of the plenum divider or or a small notch. Same idea as the ld340.I've cut the divider down, dulled the corners, on the underside also.
Being you can run either single or dual..I would only notch it..or run the single plane all together. I've never been a fan of wiping the divider out completely in a dual-plane.
