[FOR SALE] Alt brkt & pulley set
swing69
I’m just an old guy……
Central NJ
Refurbished alternator bracket, water pump pulley and 2 groove crank pulley. For small block with alum water pump. $80. Plus ride. Visible pitting from old removed rust, not smooth. From 08610
Also. 2 ft stack of misc pulleys. $50 for all. Clean and painted
I need a two groove crank, single water pump pulley, and alt brackets.
In need of single groove pulleys and alt brackets
I see you are in Canada. Do you have a USA address for shipping? I’ll have to see how much to CA is via post office..... mike
I don't, but I guess it all depends where you are im in Toronto area, I might be better off finding the stuff locally I didn't consider the weight of the pulleys
Alternator brackets / bolt, crank pulley, WP pulley from OP. $65 shipped to lower 48! BARGAIN!
