1973dusterkid
Watch This
Does anyone have some good pics of the bracket and how it mounts to the block on a altnator to a smallblock mopar.
Is there anywhere to get the bracket set without a 29.99 dollar price tag.
Don't you have a parts car? Maybe I am thinking of a different member.
If you are getting all the pieces for $29.99 that isn't bad.
It was a ac car so dfferent brackets summit has them fr 30 bucks.
I have the bottom but need the trangle bracket.
Hold the phone here guys. He didn't specify whether he is running the early or later style water pump and housing. They are 2 totally different setups and without this information would just be blowing smoke into the wind!!
Dusterkid, are you running the aluminum water pump that dumps out on the drivers side, that would be correct for a 73 smallblock Duster?? Or are you running the cast iron water pump that dumps on the passenger side, that is correct for 70 and earlier cars?? The brackets do not and will not interchange, no matter how much you shim them!!
Please enlighten us!! Geof
the 318 above is a 67 water pump , here is a 77 360 aluminum water pump.
I have this water pump I bought it new from summit a few weeks ago
That is a 1978 up pump so maybe you should get the parts that match the pump or get the pump that matches your other engine componets. Different pumps have different shaft lengths and that makes the pully set in different locations.
So this bracket will work it say it works will all years
http://www.summitracing.com/parts/PRO-66625/
Pass side
