Eworth
Hello,
I am upgrading wiring and also installing a larger alternator, a 90 amp from a 1990 Dodge 5.2 in my 64 Dart with a 318.
Also has HEI ignition upgrade if that changes anything here..
Does it matter where I run the B+ 6 gauge alternator wiring? Either Starter Relay or Battery positive?
Also, I know that this much amperage shouldn't go to the ammeter. By running the wiring directly to the Starter Relay or Battery, am I bypassing the Ammeter like I want to?
Thanks for all advice.
