my68barracuda
Hello,
I did the Denso alternator swap using a pull a part alternator some time ago into the '68 Barracuda. Using an external mopar VR....
Currently the '68 is a drag race only car and I have it set up with a remote battery and a electrical master kill switch. The kill switch is wired with one of the alternator field wires and does shut down the engine when it is switched off.
Yesterday I was getting ready to start the Barracuda, moved the kill switch to on, got in to start the car, but remembered something that I wanted to check under the hood,
As I was finishing up, maybe 20 minutes later I put my hand on the alternator body,, it was not hot, but certainly was warn,, not much, but warm..
The car started normally, I checked voltage at the battery with the motor idling,, was 14.5 V,
So why did the alternator warm up with the motor off ? Anything to look into or is that the effect of the alternator field wire being connected directly to the battery ?
thanks
thanks
