S Sixpack_Sid Well-Known Member Joined Oct 6, 2021 Messages 76 Reaction score 27 Location Pa Sep 3, 2023 #1 What am I missing? I’m guessing it’s a spacer. Trying to put my alternator on this afternoon. Hey no luck.
67Dart273 Well-Known Member Joined Oct 14, 2010 Messages 60,035 Reaction score 33,298 Location Idaho Sep 3, 2023 #2 There is a spacer that goes between the two ears on the party you are not showing us. What you have exposed is the bottom. The tensioner bolts to the ear that is up with I think a 5/16 bolt (could be wrong been awhile)
Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 14,935 Reaction score 12,298 Location Northern Colorado Sep 3, 2023 #3 This is based on SB. I See Your going bb. Check classic ind for imagery of the proper parts Red arrows point to spacers. The actual spacers and brackets will be decided buy 70? Up aluminum water pump or 69 down cast iron water pump .
Daves69 Well-Known Member Joined Feb 20, 2011 Messages 7,532 Reaction score 6,273 Location WestOfChi Sep 3, 2023 #4 ............ Electrical, Alternator Brackets :Mega Parts USA www.megapartsusa.com If it helps, mine is a single belt. Two spacers for swivel bolt and a split spacer in between, pressed into the rear alt ear..... a third spacer is behind the tension adjust bracket...........
