mullinax95
I have recently installed the 70 version charging system with the constant output alternator on my 67 Barracuda. I did the ammeter bypass upgrade also that I found using this site by madelectrical.com and everything has been soldered and heat shrinked.
The question I have is I had Accel 300+ ignition system installed on the car already and I did away with the ballast resister and put all of the wires together and everything is fine. The instructions for the performance ignition showed doing away with the the ballast altogether. Now that I installed the 70 version alternator and voltage regulator just like the diagram shows but less the ballast resistor I had to return the alternator to the store. They checked it and said it went bad. The problem that happened was for some reason the blue wire coming form the voltage regulator got so hot that it melted near the alternator. It blew the fuse on my ignition box and the car shut down and when I popped the hood I saw smoke come off of the wire. Now I have installed a new alternator rechecked my wiring with a ohm meter and everything is back to normal. I checked the voltage at the battery and it is showing 14.54 volts. The car ran fine for a while before this happend. I have however installed a 20 amp fuse on the 12 v swithed wire going to the voltage regulator just in case.
Do I need to install a ballast resistor or did I just get a alternator that went bad? Ignition 1(blue) and Ignition 2(brown) are wired together now without the ballast resistor and really that is all the difference. The car will not run with these two wires not wired together. It seems that Ignition 2 (brown) shouldn't have anything to do with it but it might. Thanks for the help.
