820 hp would push a 4000 lb B body deep into the 11s at like 130 + mph even with the skinny crappy tires from back then.. That dyno had to be way off to nearly double the rated hp of the motor. Only way to really get an accurate number would be to find a stock bare hemi block, stock crank, stock rods.. rebuild it using pistons of equal weight to stock with the exception of maybe a .030 overbore factored in. Then grind a new cam with the exact same LSA, lift duration and ramp up angles. Stock heads,valves.. valve springs with exactly the same pressure rating as the originals. No special valve jobs.. no heads with any porting or polishing. Stock intake, reproduction or original exaust manifolds, rebuilt carburetors with no special tuning. Then run it for a few thousand miles to break it in and run it on maybe 3 or 4 different dynos to get an objective idea of what it can produce.
