RDJ
I probably only have about 45 minutes run time on my newly completed engine, sounded pretty peppy. I just got the exhaust system on yesterday and heard some clicking and popping. (Before it was open headers). Anyway, I pulled the valve covers and one of the adjustment bolts for the Hughes roller rockers had backed out completely (and fallen down next to the springs), one other had backed out enough to have some slop between the rocker arm and the push rod, and a couple of others the adjustment bolts were loose and had started to back out a little (but still no slop).
Has anybody else had this problem with the Hughes roller rockers? Should I remove the rockers, clean the threads and use some threadlocker? Maybe I didn't tighten them enough to begin with? How much torque do you usually apply with the adjustment nuts on these?
Anyway, the one that backed out seems a little tough to put back in, but the threads look OK. Is this normal? I didn't want to force it too much until I made this post.
My engine is a 408 LA, Hughes 232/237 @ 0.50, .540/.548 lift hydraulic flat tappet cam, Hughes roller rockers, Edelbrock heads (hughes springs), Air Gap intake.
