Greetings,
I have settled on a 625cfm Carter AFB after my last posting. Thanks to all who responded!
I have a couple questions on the carburetor itself. Will I be able to use any AFB, or do I need to find a Model 9626/9636 which was intended specifically for Mopars?
Second, my intake (Edelbrock 7577) is a non-EGR version. Is that something that can be eliminated or closed off on a carb equipped with it, or do I have to restrict my search to non-EGR AFBs?
A brief review of my project, it is a 73 Plymouth Gold Duster resto-mod. Power plant is a warmed over 99 5.2L Magnum. Block is bored over 0.03 with a higher duration cam (duration @ 0.05 216 intake/224 exhaust), hypereutectic pistons, heavier (LS1) valve springs, and double timing chain, but otherwise stock. Goal is right around 290-300hp.
Thanks for any and all opinions.
