mopowers
I'm modifying a stock fan shroud to fit a Champion radiator. The material I'm using is 1/8" x 1.25" t6-6061 aluminum bar stock. I've been told if I anneal the aluminum, I'll be able to bend it. What's the easiest way to do this? I've read that you can do it by smoking it up with acetylene, then burning it off with a torch. Since I don't have a oxy/acet rig, that's not an option. Is there another way? Can I just heat it with a MAPP gas torch?
