So in my never ending process to make things better i had noticed my barracuda was never getting hot. figured must be missing a thermostat was missing or stuck open. It is also leaking around the gasket. SO while i go to install my dual point i installed a new thermostat and some silicone. Now my lovely is overheating. Also i must of sucked my tank because i started pukeing brown **** from the carb also need to install a new filter and start over again.. damn Now my 904 has been driping for a while but now seems to be bleeding quite well from either the gasket or the rear between the tail shaft and body, so i went to tighten just to check and it seems i have a bolt on either side that has been stripped
