dcdman67
Active Member
Hi everyone! I have read through a number of threads on wheel size and backspacing. Seems to be all over the place with the general guidance that 4.25 or 4.5 backspacing is the most common fit.
I have a stock 70 dart that I am working on. It is completely stock with the small bolt pattern. I will be using the torsion bar method to lower the front and I will be adding blocks in the rear.
I have found 2 wheels that would fit for what I am trying to do, but need some guidance on fitment. Anything helps!
Wheel 1: 18x7, 4.25, 6mm offset backspacing - Mopar Parts | AW118703 | 18 x 7 American Legend Streeter Wheel - Aluminum with Polished Center - 5 X 4 Bolt Pattern | Classic Industries
Wheel 2: 17x8, 4.5, 0 offset backspacing - Mopar Parts | AW117803 | 17 x 8 American Legend Streeter Wheel - Aluminum w/Polished Center and 5 x 4 Bolt Pattern | Classic Industries
Anyone have any advice on which one will be a better fit? Still trying to get better at offset, backspacing, etc.
I don't plan to get too crazy with tire size. Whatever fits best 225, 245, etc.
Thanks in advance!
Dan
Thanks in advance!
Dan
