Another battery in trunk question?
7dart0
peabody,ma
I have the gm Hei setup for ignition. Is it possible to run a 4 pole cutoff switch and just split the blue wire that runs to the alternator and run each side back to the cutoff switch? Then run the battery cable from the original starter relay to the cutoff switch, then to the battery? My alternator is a stock 60 amp 2 wire. I run a magnum engine with the stock mini starter.
All the schematics I see are for 1 wire alternator.
Thanks Tom
!!!YES!!! But research and find what the contact ratings are for the 2nd set of contacts. You may want to use them to operate a relay up front, rather than run full ignition/ field current through there
Ya the switch I was looking at is only rated at 20 amps on secondary. Anyone know what the field wires pull? Anyone have a easy schematic for a disconnect switch with a dual field wire alternator.
Tom
It's not just the contacts it's the entire voltage drop from the battery all the way "up" through the ignition switch, back to the rear through the battery switch, back up to the front to the ignition/ alternator.
You could split off the load, all it has to do is either kill the alternator field or ignition but not both. If you use no14 or overkill 12 wire you should be fine.
This would be a GREAT time to see if your battery/ regulator is seeing the actual battery voltage "sense" for charging. Access the wiring as close as you can to the VR IGN terminal. This might be coil + in your case with HEI. Turn the key to "run" engine stopped. Measure battery voltage right at the battery posts, then run up front and measure VR IGN terminal voltage from there to VR case (mounting bolt)
The two measurements should be within .3V (3/10's of one volt) "Likely suspects" for drop are the bulkhead connector, ignition switch, and switch connector
You can double check this running, You want the engine warm and running, the battery "normalized" for charge. Measure battery charging/ running voltage at fast idle, it should be 13.8--14.2, not below 13.5, and not above 14.5
