Another bracket question
Dubob
Ohio
So I spent some time under my 71 Demon today. I have another bracket question. I do not see the bracket that secures the rear flex line going to the differential, where it connects to the hard line. Can someone please post a picture of this bracket. It's one of the last things I need to work out before I install the brake system. Thank you.
Thanks for the reply. The end on the differential I've got the tee. The other end ,body side, the flex hose connects to a bracket of some sort for support. The point where the hard line from the front of the vehicle connects to the flex line. Sorry if the first post wasn't clear. Thank you.
Anyone able to help out with this? Thank you.
