chad h
Member
I'm building 1968 340 factory crank and rods speed pro pistons L2316 10.5 to 1 compression going to use after market heads. Ive narrowed my cam down to 2 both are crowers. cam 1 crower 31321 int/[email protected] lift 243/245 r.r 1.5/1.5 gross lift .521/.528 lsa 112 cam 2 31320 int/exh due@ .050 lift 229/229 r.r. 1.5/1.5 gross lift 446/456 lsa 112 This motor will be a weekend warrior mostly drive on the street. Both cams are solid lifter and I've just gotta use crower
