Mopar70Dart
Mopar Kid
Is it possible to take a 408 stroker kit and put it inside of a 318?
well, if the kits for a 360 then you would run into the clearance issues. 360s have larger main bearings wich also require different oil pan for the main caps.
they make a 4 inch stroke crank for 318,340 too
i think they crank around 390 cu out of the 318 with one of the stroker cranks?
someone here knows more about more about mopar strokers
