midlife89
Had my bearings pressed on but not sure if on far enuff,seems like tire is out farther now.Thrust block is still in center section,axles stock,seated in no problem.Does anyone know the measurement between the outside edge of the bearing to the inside edge of the wheel flange? Just wanted to double check it.
