TheCraigMachine
Some of you may already know about my latest combo that Ive been putting together, but Ill go ahead and give a quick rundown.
65 valiant
.030 318
302 heads ported to 360 sized port windows
1.78/1.60 valves
Summit SUM-6901 cam
8.6:1 calculated compression ratio
Magnum exhaust manifolds
2 into 1 pipes, 3" out to rear
1800 rpm stall converter
I was running a port matched Edelbrock Steetmaster 318 on this combo, with suprisingly good results, but I decided to try a better intake this go round. I purchased a Weiand Stealth intake and a 600cfm Edelbrock carb. When I looked at the new intake, my first thought was that it looked HUGE! It almost looks too big for the engine, and the runner volume is quite large compared to my old streetmaster.
Im concerned that this intake will kill my low end tourque. Does anybody have any experience running this (or an equivalent eddy RPM) intake on a ported head 318 with a mild street cam? Should I keep the streetmaster, or run a regular performer, or even the Weiand Action Plus intake? I have yet to install any intake onto this engine, and I would like some imput before i cinch one down.
65 valiant
.030 318
1.78/1.60 valves
Summit SUM-6901 cam
