68383GTS
I am mini tubbing my 67 Barracuda.I have the tub on the drivers side done,but I need to weld the seat hinge bracket back on.To put the bracket where it needs to be it looks like it wil be forward 3/4-1 inch from it original location.How do you guys fix this?
My thoughts....1.. Modify the tub,maybe cut a hole in the tub and box it in so the bracket will fit in its original location.
2.. Leave the original brackets on the tubs in the original locations, and modify the seat hinge.
3..Make new brakets,weld them to the front of the tubs.Then move the seat foward about 1 inch.
Thanks,Jim
Thanks,Jim
