Another Tire Size Question?
Woody'sScamp
Penfield, New York
All,
I thought I had this figured out, but no. 1975 Scamp, 318 engine. I want to run 245/60/15 on the rear 4.50" backspace rallye wheels.
Is anyone running 215/65/15 on the front with 4.25" backspace rallye wheels?
Or should I go with 225/60/15 on the front? Copper Cobras or BF Goodrich are my choices.
Thanks
I'm running 245/60/15 on 15" X 7" (WheelVintiques) Rallye wheels with 4 1/4" backspacing (factory 8 3/4" rear-end with ManciniRacing 2800lb leaf springs (factory location)). I could have gone with 255/60/15 tires (next time I will).
Up front I have 195/75/14 on 14" X 5 1/2 (factory) Rallye wheels with 3 3/4" backspacing (if I remember correctly). I do have SSBC-USA disc brakes which set the wheels outboard ~3/8". I had 215/70/14 that rubbed during tight turns, so I opted for the 195/75/14 tires.
I like the way your car looks, the stance. I need 15" tires on the front because I bought the Dr. Diff bigger front brake kit.
