Haney
www.carsonandironmt.com
I am pretty sure I have my back wheel spacing and tire size figured out. Pretty straight forward because it is not moving around like the front.
For the front... On a 72 Dart Swinger with 73+ Disk brake Conversion will a 17x7 with 4.5" of back spacing and a 225/50/17 tire fit and look correct on this car? With my measurements, I am thinking they will, but want a gut check before I lay out the cash.
Is there a better combination fo wheel size / backspacing / tire size for the front that I should use?
Thanks in advance.....
