Im not sure if there is a formula for psi to compression ratio but was wondering if these numbers are close for a compression test on a 340 with X heads. I did not build this engine and dont think either of the two previous owners ever got it running. It seems to run very strong and obviously has a very lumpy cam. If any of you can remember what your compression tests yielded would you say this is a stock 10.5:1 compression ratio?
#1) 140 psi
#2) 150 psi
#3) 140 psi
#4) 140 psi
#5) 145 psi
#6) 140 psi
#7) 140 psi
#8) 145 psi
Thanks for you opinions
#1) 140 psi
#2) 150 psi
#3) 140 psi
#4) 140 psi
#5) 145 psi
#6) 140 psi
#7) 140 psi
#8) 145 psi
