Some rabid comments
(I guess you meant 6M not 60M)
Nope, I meant 60! On July 3, 2003 the FCC opened up 5 specific channels on 60 meters for ham use. 5330.5 khz, 5346.5 khz, 5366.5 khz, 5371.5 khz and 5403.5 khz. Hams have secondary use of these frequencies and must not interfere with the military and are limited to 50w ERP. Pretty cool though! Obviously this is for general class holders and above only.
That Cushcraft "depends what you want to do." if I wanted an antenna (here) to work repeaters and for general use, I'd just put up some sort of ominidirectional, like a vertical, that is for 2 meters.
Second, most people working DX simplex on 2 want HORIZONTAL polarization, not vertical. I didn't read the whole pdf, but saw no obvious mention of being able to configure the 2m section hor., only pictured as vertical.
I read a review on this antenna where they called Cushcraft and they stated that the main tubular beam could be rotated 30 degrees for the best of both worlds and supposedly the user did and still was able to achieve skip on 6m. :read2: My logic in thinking that thnis would be a good all around antenna is that with vertical polarization on 2m/70 i would be be able pick a repeater and shoot right at it but still be able to rag chew with a given individual (simplex) once i dailed in thier location.
After reading your response I just realized that having a vertical beam could cause issues if I were on a net, as some may not be able to hear me and I'd have to track someone who was mobile. This could be a PITA and would make more sense if I were 30+ miles out of the city rather than centrally located, which I am.
Thank you so much for your input and it is hardly rabid and as a matter of fact, it is greatly appreciated! The Cushcraft is out and a 2m/70cm vertical omni is in. I sure would like to try some 6m DX in the future though but it appears that the further I want to go, the more it will cost, lol. I think it would behoove me to just get in on the local stuff and refine my technique and get to know a few guys. I have tons more to learn.
It might be a PITA to rotate it a lot for different repeaters in your area--but it just depends. I'd find out what you NEED for local work
In light of last comments, I wholeheartedly agree. It might be be fun to hit the repeaters in Colorado Springs with the 2m/70cm vertical beam but other than that, I really don't see the use of the cushcraft, in my geographical area with the exception of having the 6m horizontal beam for some state to state dx.
Also, don't go by an antenna's weight for a rotator. You need to go by the rated WIND LOADING which I believe stated 2.5 sq ft. If you live in a gusty, high winds area you might want to add a fudge factor. Ask around locally to see what the locals are doing.
(It depends on what you call a TV rotator, too)
If you live in a winter area that sees wet snow and ice on power lines, that will add a HUGE factor to antenna loading.
I was looking at a high end tv antenna rotator, about a hundred bucks.
Frankly, if I were you, I'd put up a simple little vertical--you can MAKE a 1/4 w antenna in minutes, there are scads of "how to" around the www
There are SOME articles you can download from the ARRL, but unfortunately you have to be a member for much of it:
You have to browze the left side menu, a PITA
http://www.arrl.org/radio-technology-topics
quarter wave:
http://www.hamuniverse.com/2metergp.html
http://www.hamuniverse.com/kc0ynr2metergppvc.html
http://v33.takeforum.com/2009/01/19/simple-2-meter-ground-plane/
You can google "j pole" until you are blue in the face
I'll check that out. A fellow hammer told me was actually able to hit Colorado Springs with a 500mw HT and a homemade dipole! QRP is cool!
One thing I advise you to investigate is whether there are any "on the air" swap nets or clubs in the area. Look for "ham fests." What I'd suggest is that you find a couple of ARRL handbooks. They can be found pretty cheap, even on Ebay. Some of the older ones, back in the 60's are interesting, but mostly "tube" oriented. But I've picked up a 90's edition CHEAP at a hamfest, and the theory hasn't changed--only the way projects are built.
