Ya, Honda. Its a side job I took on. Guy brings out a 97 CRV. 170k and seems to be an all around POS. Brings rear brakes and rear bearing He was told it needed. Its not the bearing. I could be a ***, put the bearing in, collect My money and give it back. But Im not trying to do that and Hes My Sis in laws co worker.
Making really tight turns, in either direction it makes a really bad noise, a grinding squealing noise, and You can feel the grinding in the car. Its not a bearing, not a drive axle. AWD. Jacked up, spinning wheels by hand, the diff sounds terrible. My mitchells have no diagnosis. This thing has funky diff with a clutch assembly in the front. A "torque control differential". Does this sound like the problem. Exploded view seems simple enough to rebuild. Any thoughts/ideas would be greatly appriciated. Thanks, Andrew
