Any idea what these hub caps are from?
Any idea what these hub caps are from?View attachment 1715011624
those are not "hubcaps" but rather WHEEL COVERS ....hub caps are the small ones that only cover the hub, which is why they are called hub caps.
This style of 14 inch wheel cover was available on 1970 and 1971 Dodge dart and 1971 Dodge demon.
The center insert which says dodge division seem to be faded and worn.
This style of wheel cover is very nice and makes these cars have a very original appearance.
Dodge Challengers had a similar style wheel cover offered in 1970, they are similar to these ones, but had ''Challenger'' written on the inserts.
Of course, these are the A-Body ones which you have pictured, which are more common.
Just throwing it out there.............
Also used on some B & C bodies, so if you need a set, broaden your search. ;-)
