your confused?? LOL... I've been confused !!
Are you jumping from orange to brown wire. Is brown wire NSS circuit.
yep. But the brown goes straight to the starterAre you jumping from orange to brown wire. Is brown wire NSS circuit.
bottom of the starter relay.. you can see the orange. I'm jumping from the orange to the brownwhere does the orange wire go.
haven't done anything. Holidays and all. I'll try a new nss first. Easy to get to.Ok is it fixed?
they "look" fine. Could be something in the wiring, though, that I can't see. That's why I thought the NSS would be fast to tryI would check the wires and the plugin first.
.they "look" fine. Could be something in the wiring, though, that I can't see. That's why I thought the NSS would be fast to try
NSS switched fixed the jumper wire situation Starts fine now without the jumper wire.
If one of the wires is broke inside its cover that could be causing your whole problem.
Or it could be a connection. Or connector
